AUXILiARY FUEL TANK
woodworker414
Good afternoon from chilly central FL.
I know I have asked this question before. I have entered the words in the search box, but no results.
Those of you that have added a AUXILiARY FUEL TANK.
Which one did you purchase?
Did you do the install yourself?
I am giving serious thought of putting one on the tuck this spring.
Your thoughts both pro and con.
Brenda and Bill
2020 Lance 1172, our traveling rig
2013 Heartland Landmark Mesa, 40', fifth wheel, we keep at our snowbird home in central FL, Bushnell, FL.
2014 Chevy Silverado LTZ 3500HD, CC, 4x4, LB, duals, DuraMax
122 REPLIES 122
woodworker414
Dave H M, thanks for the info. I am still here for little bit. I will check to see how far it is to their location.
Brenda and Bill
4x4ord
If you really want a cheap solution you could weld a couple hose barbs onto the steel rim of your spare tire and plumb it into your fuel tank. It would hold a good 25 US gallons.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
Dave_H_M
wood worker, if you are still there.
RDS tanks are made in Perry FL.
They will make them to your spec. And if you are close you could pick it up and save shipping.
woodworker414
Thanks everyone for the replies. Yes a type,AUXILIARY, I think I do real good for a guy who has lost 85% of his vision.
I have weighed the truck and rig, on a Cat Scale. Ok there.
I also like the idea of being able to fuel up maybe every 2 days. And maybe not have the rig on the truck. Plus we want to travel the US highways, get off the interstates highways, and explore.
I will research the different brands that were listed and see what I think will work for me.
Thanks again for the replies.
Brenda and Bill
packnrat
Lantley wrote:
I have a 25 gallon Enduraplas tank. I consider it the poor man's aux. tank. Nothing to install but I do have to pull over to fill up!
Works like a champ!??
mine would have been bed height, but i put mine rubber mounts under for vibrations, and so the gunk can get out.
2006 F250 4X4 auto 6.0 short bed
2001 sunnybrook 24 ft
1984 cj7 built up a bit
kg6tgu
never too many toys, just not enought room to keep them
one dog who belives she is the master. rip 12 12 2007
12 loving years and loyal to the end.
just out having fun
Bionic_Man
60 gallon RDS tank/tool box combo. Had it installed when I bought the truck. REALLY nice mod.
It isn't about saving $$. It isn't about "I need to stop anyway", it is about choosing when/where you stop.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
2naEagle
50 gal RDS #74026 with gravity feed.
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Greyhawk 29MV
Lantley
Veebyes
Sorry,bought the truck with tank installed. Really nice to have especially where fuel stations are few & far between or passing through an area of extra high prices.
Nice thing about mine is that it is bed rail high but is half fuel half storage. About 35gal fuel.
2007 Alpenlite 34RLR
azdryheat
91 gallon RDS tank with tool box that I installed. Absolutely love having all that diesel on board, good for about 1,000 miles towing my triple axle toy hauler and filling up when I want to and without the trailer.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
packnrat
i just have a cheap 36 gallon from tractor supply. i had to add in one bung so i could have a sight tube. but i just flip a man valve to gravity drain into the factory tank. but i did weld in a connection to the factory fuel inlet (yes it was off the truck for this). and yes a fuel filter in this assembly.
O and i did add in a grounding strap, needed?? i get a lot of static discharges. can hurt at times.
i went cheap and simple.
kg6tgu
just out having fun
fj12ryder
I have a generic 35 gallon steel from The Farm Store with an electric pump and hose/fuel nozzle. It gives me about 75 gallons total of fuel. Enough that I fuel up when I want rather than when the truck says I have to, wouldn't be without one.
Probably about $400 total spent. One of the best traveling accessories I've gotten.
Howard and Peggy
"Don't Panic"
dmck413
40 gallon gravity feed. Came with fitting, wired in solenoid to control flow. LOVE IT. Fuel once a day
B_O__Plenty
62 gal RDS wedge with gravity feed. Drill 4 holes in bed. Three for mounting, one for fuel line. Install a grommet on fuel line hole. Install fitting from install kit in fuel filler hose. All you need to this is a sharp utility knife if the hose is rubber. I did one for my friend in 30 minutes total. Have had mine in two trucks now. Never a problem. Works perfectly.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
laknox
Bill, not trying to be the weight police, but do watch your payload and make sure the size tank you want will fit within your truck's specs. If you've not scaled your rig, ready to camp, I'd highly recommend doing so, so you know =exactly= how much payload you've got to play with. Heartlands aren't noted for being light. Just sayin'...
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
