E_mc2's avatar
E_mc2
B & W Companion Lube Plate use question
Hello all,
I am still new to fifth wheel towing and I had a question regarding the use of a lube plate and a Companion. I currently run the Companion with the standard 1/4 inch Lube plate, My question is should I be running the 1/8 inch lube plate instead. The reason I ask is the jaws on the hitch are pretty much the same size as my pin. Sometimes it doesn't want to unhitch real easy and I was wondering if that is the cause. If you have a Companion do you use a lube plate? Standard thickness or the thin one? Ever have trouble unhitching sometimes?
Thanks
