โJun-15-2015 02:03 PM
โJun-23-2015 11:01 PM
gkainz wrote:
Last campground was exactly this way. A loop (counterclockwise traffic) with campsites only on the outside of the loop. All sites angled about 45ยฐ so if one would go the wrong way around the loop it would require a 135ยฐ cut into the site.
โJun-23-2015 08:41 PM
robwhite61 wrote:
Tip 1: Do everything possible to insure that you will be turning on the driver side. Even if it means driving around the campground and up/down a few roads to get yourself turned around. Passenger is your blind side and should be last resort.
To me this is the most useless instruction. Every campground I've been to has one way streets and most of the sites are angled to aid in backing in when going the right direction. Just my experience and .02 worth.
โJun-23-2015 08:38 PM
โJun-23-2015 07:01 PM
robwhite61 wrote:Tip 1: Do everything possible to insure that you will be turning on the driver side. Even if it means driving around the campground and up/down a few roads to get yourself turned around. Passenger is your blind side and should be last resort.
โJun-23-2015 05:32 PM
โJun-23-2015 01:01 PM
โJun-17-2015 09:48 AM
โJun-16-2015 01:50 PM
Allworth wrote:
Two smart phones on speaker, unless you are way out in the boonies.
I turn the volume up and drop mine in the cup holder.
Also, empty parking lot and practice, practice, practice!
โJun-16-2015 09:28 AM
โJun-16-2015 08:29 AM
โJun-16-2015 08:04 AM
โJun-16-2015 12:23 AM
โJun-15-2015 08:52 PM
Hvyhauler wrote:MTPockets1 wrote:
Most important to me; don't have anyone out there pointing or directing left, right, or whatever... There's some decent advice given here, but again for me, trying to back and watch the wife or anyone else does nothing... I pull well ahead, get out and do a walk around of the site making mental notes of overhead obstructions, power poles, water spigots, table, etc. I then imagine about where I want the trailer wheels to stop, keeping in mind where those obstructions are, and distance from them allowing enough space for slides; and then back slowly with that spot as my target. I'm the one with the wheel, and any "helpers" distract.
X2... Excellent advice,the same way I do it...also I've respectively declined the help of the peanut gallery which comes out of nowhere on a couple of occasions.
โJun-15-2015 08:05 PM
