smithrjd wrote:
I am sure this has been discussed before, and I did look around in the search section. Does anyone have a wireless system on a 35' 5th wheel that works well? Looking at Furrion, Emmako, and others. The Furrion is a bit different and much more expensive. All of the others seem to be pretty similar. Seems distance and what is between the camera and monitor is the issue. I am guessing I would be around 40'. 2011 Jayco Eagle, so nothing pre installed.
The tick for good range is a good 12V supply to the camera. Our 2017 Bighorn that is 39'4" long came with the Furrion mount pre-installed and hard wired to 12V from a sconce light on the back wall next to the window. I installed a second switch on the light so I could turn the camera off when not in use.
Never had range issues. I could drive 600' plus from the trailer and still have reception at the display in the CC truck. We parked the Bighorn at our NW park and moved the camera to a TT we bought that had the mount and camera wired to the clearance lights. With LED lighting on the TT the camera works fine.
