selnoil
May 18, 2017Explorer
bad tires , best replacement 235/80r16
Hello All,
I am sure this has been asked 100 times but I am new to this forum and search did not find what I need. I have a 2012 nearly 40' Keystone 5th wheel that is about 10-11k dry. This past weekend we had a blow out on the right rear causing several thousand dollars damage. The tire had a cord failure even at proper pressure and such. The current tires are Power King Towmax STR 235/80R16 load range E's. Looking them up it appears many people have had the same failure.
Anyway long story short what have you found to be the best tires out there with the least failures. I am going to change them all based on what I have read with failures of them.
Mike
Mike
