GoPackGo's avatar
GoPackGo
Batteries Overcharging ?
I have 2 group 29 house batteries that are about 2 years old. I just checked and they are hot and appear to be boiling off fluid. Can this be caused by one (or both) bad battery that won't take a charge, resulting in the charger continuously charging at a high rate ?
I added a lot of water last week but I just thought I was behind on my watering.
I just flipped the main battery switch to 'off' until I get this figured out. They were getting pretty hot.
I have a 2014 Heartland Bighorn. Will have to call Heartland and ask where they hid the converter/charger.
Thanks for any help on this.
  • Measure the charging voltage and post it up.
    Then disconnect and separate the batteries and let them sit 24 hours and post the voltage still resting.
  • Yes, a bad battery can cause the charger to overcharge. The only feedback the charger gets from the battery is how much current it is drawing, so a damaged battery can keep telling the charger it needs more charging.
