battery boiling
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
โJun-28-2014 04:56 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-01-2014 05:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-01-2014 02:47 PM
TV - 2017 F350 SRW CC SB 4X4 6.7
TH - 2015 FR XLR 395AMP
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJul-01-2014 02:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 10:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 02:45 PM
I'd get the pendant too so you can see the charge level remotely. It's only another $11 and it plugs right in to the new converter. Clicky again...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 02:38 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 09:43 AM
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 05:38 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 05:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-30-2014 04:58 AM
When you leave the battery connected to a charge source of 13.6VDC you should be checking the fluid levels. I check mine every couple of weeks.
Once the battery fluids get below the cores inside the batteries then the battery may short out internally. This will make the battery start getting hotter and hotter and really start boiling out more fluids.
It is hard to re-cover a battery from these problems.
This is why a SMART MODE CHARGING setup is so important for us. These system will use all of the necessary charging voltages to keep your battery re-charged. More importantly these units will drop back to a 13.2 VDC mode when currents are not being demanded by your system. This charging 13.2 VDC mode is just below the boiling out of fluids level and really saves your long term connected batteries.
I check my batteries on a regular basis using my MULTIMETER and watch the charging voltages coming from my on-board converter/charger unit or connected to the truck charging system when pulling my trailer very close to make sure all is doing what it is suppose to be doing...
ALot of us RV'ers can't afford to keep replacing dead deep cycle batteries where just a few simple measurements on a good maintenance schedule would prevent the batteries from going dead.
Just some of my thoughts
Roy ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-29-2014 05:12 PM
You still need to get a multimeter and provide us with some voltage measurements. You do have a multimeter...right?
Ron
TPMS: Pressure Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-29-2014 04:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-29-2014 10:51 AM
Checked every month if I remember. Every other month if I forget.
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
โJun-29-2014 10:21 AM
But would not recomend leaving them too long really without checking them.
