joelc wrote:
Currently I have 1 12V unit and can not fit another. It is a Super Start SSB 31DCM. I power a 12V compressor type fridge and all other 12V RV lights, etc. So I need 1 reliable 12V battery. 2 large wont fit. I am looking for something under $200.00. Brand and Model please as there are different models of specific brands of 12V Deep Cycle. I dont think 2 6V will fit.
If you are on shore power, any cheap 12v battery will work fine and hold up for several years.
If you are operating off shore power any single battery (at least a lead-acid battery that fits in the same space) is going to be too little.
Now to some details:
- If you are on shore power, your 12v needs are provided primarily via the battery charger (aka: converter). The only thing the battery does is smooth out the voltage as a pass thru...some chargers don't even need a battery in the mix. On shore power a tiny riding lawnmower battery would be plenty.
- Assuming we stick to lead-acid batteries (lithium is a whole separate topic), most single 12v batteries are going to going to max out somewhere around 100-120amp-hr. You can really only use about 50% without damaging the battery, so around 600 watt-hours is available. We have a 12v fridge and it draws around 50w when running, so if you have no other 12v draws, it's good for about 12hr of run time (600w-hr/50w = 12hr). In reality, you have other 12v draws, so if you are boondocking occasionally away from shore power, you are probably dragging the battery way too low and resulting in a short lifespan. You either need to run a generator or add more batteries. If you add more batteries, you need a way to recharge them (see the comment above about doing an energy audit).
