Cummins12V98 wrote:
Nice!
I am betting a suspension lift is next on the to do list for the RV.
If keeping your RV I highly advise spending the $$$ and getting the MORryde IS suspension. They can dial your RV to be the perfect height for your truck.
Ask FTG his opinion on that mod.
Yea, That Cameo looks to be riding low with that old ford..Once you switch you may find that the front of the trailer will be way up in the air as all the newer trucks are so much higher..
I've had the MORRyde IS put onto my last 3 fivers
When You pull into their lo they will-
pull you on a straight line and measure your current set up from ground to frame and ground to top of highest point in 3 different areas. then Then they measure the distance from truck bed to fiver overhang..
They will then back you into their garage and start the work, They go off the measurements and build a subframe to be welded onto the frame of the RV..This way once done you will ride 100% level from from to back.
They used to scale each wheel placement before anything, but they did not do that this last time...
This and Disk brakes are the best 2 Mods one can put onto a heavier trailer... That is, if your gonna keep it..
