Njmurvin's avatar
Njmurvin
Best way to switch from shore power to inverter?
I'm planning an upgrade to my solar capabilities which are quite minimal at the moment. Part of the plan is to use an inverter to power all the AC outlets when dry camping. I would probably be satisfied with a manual switch. But, 30 amp auto transfer boxes can be had pretty cheaply - so that's tempting. I just want to switch between shore and inverter power (disabling power to the converter/charger when in inverter mode). If I use a generator, I plan to use a portable and just treat it as shore power.
Is there a simple way to accomplish this?
