Blowout Albuquerque
Atom_Ant
Was heading to the airport Friday pulling on to I-40 in Albuquerque. Merged in next to a 5er and I had just noticed his front tire start to bounce when boom!.........tire shrapnel everywhere.
Based on the tread section laying on the hood of my rental car, I'm positive it was an ST tire. This thing didn't run flat, didn't shred a tread, it just exploded like a baloon leaving barely a trace that a tire ever existed on the rim. How anyone can defend these as safe tires for the road is beyond me.
Hats off to you whoever you were! You brought that rig to a well controlled stop on the inside emergency lane.
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
25 REPLIES 25
JIMNLIN
One thing I've found is as a tire tread wears down it runs hotter or put another way my new tires ran cooler when new as they sit up on the treads blocks/grooves for more air circulation .... after the tires wear in period.
As a young man in the '50a/'60s the trend was to run tires down to the cords. Boy did they ever get hot at speed.
The picture of the tread of a ST looks like several ST brands.
Some one says don't get hung up on details about a tread pattern. Good advise as there are several LT tires out here with different A/S tread patterns that make excellent tires for a road trailer.
Me_Again
Design 1 General OTR Trailer Tire
Design 2 Goodyear OTR Trailer Tire
Design 3 Yokohama OTR Trailer Tire
Design 4 Bridgestone OTR Trailer Tire
Design 5 Bridgestone tire suitable for RV Trailer service Wow, same tread as the OTR trailer tire above!
Design 6 Michilen tire suitable for RV Trailer service
Design 7 Goodyear RV Trailer Tire
Anyone notice that all of these tires have similar tread patterns that are nothing like ST tires? Not one of these tires has a broken outer rib like most ST tires.
Chris
FastEagle
Atom Ant wrote:
thomasmnile wrote:
Atom Ant wrote:
Brand didn't matter, it was the universal tread pattern for the ST. No rocket science involved.
:h I have ST tires (Chinese, no less) on my TT. Tread looks nothing like the photo posted. So, how is that a "universal" tread pattern?
Don't get hung up in the details. I'll put it another way for you - You won't find that tread on anything but an ST tire :R
ST tread designs should not be stereotyped. Here are a few examples you may have overlooked. With any other tire there are tread designs that are most favorable for the conditions the tire is designed for. The shallow tread found on ST tires are designed - in part - to help cool the tire.
Design 1
Design 2
Design 3
Design 4
Design 5
Design 6
FastEagle
Atom_Ant
thomasmnile
brownmht
I had 2 tires shred on me just after we headed home from TN. I just happened to look over at the wife just in time to see the tread fly off. It kept the air in the tire and I was able to get off the highway and into a parking lot to change the tire. The other one shed the tread and I didn't notice until a day or two after I got home and found the tire was flat.
jwduke
{Quote}Maybe, someday..........there will be millions of Redwoods sold and the light truck tires will be normal. Right now light truck tires on fifth wheel trailers are uncommon.{/Quote}
Hitchhiker (NuWa) & Excel (Peterson Industries) have been using LT tires for several years. Our '03 Hitchhiker came with LT's on it new.
'04 Dodge 2500 QC 4x4 w/CTD
'03 Hitchhiker II 31RLBG
Swamp_Man
Back in 2006 when we ordered our 2007 Arctic Fox, we ordered the then rarely used 16 inch rims. We were pleased when the trailer came in with LT tires. They lasted and were replaced this year due to age.
Steve & Trudy Jackson
2018 Cyclone 4005
2016 Ford F-450 6.7 PSD
AirSafe 25K hitch
kakampers
I can understand your concerns when you're running light truck tires on your Redwood. I believe all Redwoods, approximately all 5,000 or so that that have been built to date, are running light truck tires due to their weight. Apparently, no manufacturer makes an ST tire that can handle the weight of a heavy Redwood.
I believe that there are maybe millions of travel trailers, 5ers, equipment trailers, and the like out on our roadways on a daily basis. I know our safety is at risk. Its all in the numbers.
Keep pluggin' you may be able to change all that:)
Actually Redwood came standard with the ST Goodyear Marathon, and until this month, the G614 was an option. It is now standard. Probably less than 20% of the Redwoods out there have the G614, therefore they are also plagued with the vulnerability of ST tires.
Landmarks have come standard with G614 for years now, and just this year Heartland added 17.5 tires and rims with disc brakes as an option....at least manufacturers are starting to be proactive.
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
Infinityrver
Woops! Meant to write "banned" not band. On my previous post. Must be early.
'12 Infinity 3850RL
'11 Ford F350 FX4 Diesel
Infinityrver
Like I said, "Keep pluggin". Maybe, you can get ST tires band across the nation.
'12 Infinity 3850RL
Me_Again
And Barry disagrees with me, but I think that A/S type thread is causing ST to rip their cap off! Chris
Atom_Ant
Atom_Ant
