dsrace wrote:
valhalla360 wrote:
Any chance you took it to the cat scales since it's spring?
It's less than $20 to get real data rather than more guesses and salesman who have no idea selling you something that may or may not fix the problem.
so i have not taken it to the cat scales. i do intend too but with all the work i had to do to the toyhauler to get it prepped for a trip, i ran out of time. i did put the weigh safe hitch in to check tongue weight. dune sport said they weighed the unit at the factory. i know that doesn't mean much until verified but the stated 7200 lbs empty with 1200 lb tw. so , according to weigh safes hitch, i have 1250 lbs tw empty. when i say that, i have bedding on the bed, prob 100 lbs of gear under the bed, 50 lb steel tool box in place of the lead acid batteries, fully stocked bathroom, with kitchenware and pans but no food, clothes, tool boxs or sand rail. 1300 lbs tw in that stage, so they were probably correct. pulling the sand rail in that drops to 750 lbs tw ! backing the sand rail in that stays at 1300 lbs, with rail pushed to the ramp gate as in the tires touching the ramp gate. the ramp gate down drops 100 lbs of tw vs in the closed position. thought that was interesting. i have 12" of room to push the rail forward and back with it backed in. so moving it forward to almost touching the fridge adds 200 lbs tw! that was surprising imo as i never would've guess that pivot point was that close. with the camper fully loaded for sand dunes trip, rail 4" off the gate, 100 lb tool box loaded against the gate, two folding chairs against the gate, fresh, black and grey tanks empty....... 1250 lbs tw. i am using an anderson wdh for the sway reduction more then the wdh part. with it set as it was before the front end drops .5" lower then unloaded height, back end ( measuring from wheel wells to the ground) sits 1" higher then the front with only 15 psi in my rear air bags, a tool box, a decent load of fire wood and a green mountain smoker in the back of the truck. heading out now for a dune trip so we will see how it pulls this time with 1250 lbs tw. i will make an adjustment to the hitch along the way.
they stated 7200 lbs empty, i know the sand rail weighs 1960 lbs wet, i know the roll around tool box i take weighs 100 lbs, i know the steel storage box/tool box i mounted in place of the lead acid batts on the tongue weighs 50 lbs empty, 7 nuts bolts small parts organizers under the bed that easily weigh another 100 lbs..... all loaded up, empty water tanks, i wouldn't be surprised if it weighs 10,200 lbs loaded.
