milo
Jun 19, 2014Explorer II
Broke Our SuperGlider
Well I managed to bend the locking mechanism on our 2700 PullRite superGlider on only our 2nd tow. Went thru all the pre-checks before backing under the King pin to latch, backed up got it latched, pulled the 5er the 75 miles home and went thru the check-list to unhitch, pulled handle to open the jaws, jaws seemed to open, raised 5er to just off the hitch and pulled forward and would not come out from underneath it. Jaws looked open, but wouldn't let it slide out, so I lowered it & then raised it back up, still would not come out. I pushed on the locking lever and the round ring clip and 2 flat washers & the locking lever fell to the floor ...BROKE. After checking the locking lever saw it was bent on one side. Now I could get the jaws open but could not keep it open so I had to hold it open so DW could pull the truck out from under the pin.
Has anybody else with the 2700 15K Pullrite SuperGlder had this problem. Good thing we were at home unhitching when this happened.
A call to PullRite tomorrow is in order. Also there is a service center for PullRite locally so will also be visiting them.
Milo
Milo
