Depends....First if the tank is empty. It will be as soon as you remove the valve! You will have to look at what is there. If all of the fittings are glued end to end with no room for a coupling where you need to cut the pipe, you will likely have to replace everything from the valve out. If you have roughly 5 inches of straight pipe attached to the valve, it will be a simple process.
The valve itself is 4 bolts and remove.
I basically had to replace everything from the valve out after a tire blowout. I took everything off as one piece and walked into my local, small town RV repair shop. We mocked up the replacement right on the counter. I then went home and installed and glued each piece just like the original.
