jrp
Nov 06, 2013Explorer
fly4fun wrote:
.... Do you guys like the roll up doors or the panel door on a track best? Thanks for all the pics guys. You all have some neat toy boxes.
Mine are regular rollup doors, with manual chain operators. You can get electric operators at an additional cost, but I didn't see a need. I only use the roolups when I'm moving a rig in or out. Insulation is a valid issue, depending on your location. I insulated my walls & roof significantly, but not the doors. out here in the desert, although we do occasionally get below freezing. its not severe or extended cold. I don't heat or cool the open garage area, it stays at least 20 degrees warmer/cooler than the outside temps with just the insulation. I do have a closed off, finished apartment like living area in the 3rd bay (15'x60') where I have heating & cooling, and additional insulation.
One issue I've noticed out here with the rollups is wind blown dust. When I return here each fall, the 1st day is spent cleaning out a half inch of fine dust that blew in under the door bottoms & sides during the summer. After one of our rare winter snow storms here, I had a 6" drift of snow just inside the bottom of the rollup doors. There are probably add on systems that would provide a better seal around the doors, but it really hasn't been that big an issue for my part time seasonal use.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 23, 2025
