Carri-Lite 36XTRM5 questions
outwestbound
Hi. Looking at buying a 2010 36XTRM5.
Does anyone know if access to the refer, bathroom and bedroom is possible with all the slides closed?
Is the dryer prep ducted to the outside?
Thanks
2011 F350 6.7L, 4WD, DRW, 8' bed, Reese Elite 25K
2011 Carri-Lite 36XTRM5, MOR/ryde IS, 8K disc brakes, 17.5" wheels/G114s
Solar: 960 watts, 3,000 hybrid inverter, 830 AH bank, 2 controllers
IT: weboost 4G-X, WiFi Ranger Elite Pack
8 REPLIES 8
luvglass
Enjoy your new Carriage, they are great rigs. There is a very active Yahoo group that you may want to join. They can help you with just about any problems.
https://groups.yahoo.com/neo/groups/Carriage_RV/info
Good luck,
Fred Wishnie
2006 Carriage Cameo 35KS3, 2006 Ford F350 diesel dually, fulltimer
See our blog at http://www.mytripjournal.com/wanderingwishnies
outwestbound
I contracted to buy a 36XTRM5 sight unseen. I checked it out today prior to closing and love the floor plan. I'm very happy with the unit and also bought the fellow's F350 truck; both 2011s.
Traveler_II
The vents I've seen have been vented through the walls.
2011 Cameo 34SB3
2014 Ford 350 King Ranch, Trailer Saver BD3 Air Hitch, Mor/Ryde pin box, IS Suspension, Disk Brakes
Nights Camped in 2012 - 142
Nights Camped in 2013 - 186
Nights Camped in 2014 - 185
Nights Camped in 2015 - 231
Nights Camped in 2016 - 162
outwestbound
Traveler II wrote:
If possible I think in the long run you would like it better if you vented all that moister outside.
Is retrofitting a vent through the roof common? If so, I'll go this route and agree on the moisture.
Traveler_II
2011 Cameo 34SB3
outwestbound
Thanks so much. I was thinking about getting a combo unit so I'd have the top half of the W/D closet for storage. If there is not exterior vent, they make a non-vented unit so I guess I'll look into that type of W/D.
kennethwooster
My Cameo also came without outside vent. I suppose a person would have to cut one. Reallly don't know. You will love the quality. Awesome trailers.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
chiefneon
Thanks
"Howdy!
We have a 2003 36XTRM5 and yes you can. The refer is located directly infront of the entry door. You only problem is the bedroom is a open area you will have excess to the bathroom but the bed slides into the wardrode slide on the curb side. So you would have to open one or both slides to use the bed or crawl up onto the ibed if not. But yes refer and bathroom are no problem.
Our washer dryer prep only came with electric, hot and cool water connections. No dryer vent to the outside.
"Happy Trails"
Chiefneon
