laknox wrote:
Cummins12V98 wrote:
Coach-man wrote:
The problem is you leave the valves open! The system is not designed to do that, you get build up and it clogs the pipe. To try and fix it you need to open the hot water faucets and hope it is enough to dissolve the build up! Both tanks, black and grey are called "holding" tanks. They are called that for a reason, they hold the contents, and then are drained. This action "sweeps" out any build up and keeps them clean! If you are able to get the tank clean, please do yourself a favor, and keep the valves closed, until the tank is full, then drain! Simple concept, why do so many people think they know more than the engineers who designed and built these systems?
When hooked to sewer I have left my grey tank open, been doing so for many years and full timing for nearly 6. I do once a week turn on tank spray, close valve and fill tank while doing black tank then open.
Never been a fan of being in the shower with the pan filling from the tank being full.
Personally, that's why I check the monitor =before= I get in the shower. :B Also, DW knows where the grey water handle is... :B
Lyle
Do what you want, but the bottom line is the tanks are called "Holding" Tanks! They are called that for a reason. Whether black or gray, you have solids in suspension, in order for them to drain properly you need pitch, (which is what you should have at home). That pitch allows the liquids to quickly run down the pipe, carrying the solids with it. In an RV, the tank is flat, and level if you did your job correctly when setting up. There is no pitch, yes the liquid will find the lowest point and drain, but but nearly fast enough to carry the solids. Every post I have seen, about clogged smelly tanks, the op states they leave the valves open on full hook ups, (To lazy to go out and drain the tanks?)!
If 12 valve has been doing this for years, and still does not know when to drain the tanks, so they won't back up into the shower, then there is not much hope! One you have a gauge, check it! Two you should know how much water your family uses, and can figure out how long you can go before draining the tanks! It is not rocket science, it can be done!
