r1Mk
Mar 07, 2018Explorer
CO replacement help
It's time to replace my CO detector but it's hard wired (takes battery also). The wiring does not have any connectors I can disconnect. Can I just cut the wires and leave them stuffed in the wall and install a residential detector that runs on battery only.
MOD'S EDIT: I changed CO2 to CO for you. Lots of amateur chemists here will beat you up all day for that extra oxygen atom that changes carbon monoxide to carbon dioxide.
