Rockinfigs's avatar
Rockinfigs
Crack in gel coat
Hi I have a hairline crack in on the side of my hauler.. Little larger than a hairline but it's pretty thin.. What's the best way to seal it.. I was think of just putting some clear Chaulk and working it in with my finger so no water gets in it. Any suggestions
  • I would get a can of automotive clear coat. Mask it off to just expose the crack and spray away. If it’s a small crack you want something fairly liquid to fill the crack. The caulk may also work but I would be afraid it would attract dirt and look bad. A body guy told me the least intrusive method would be to give it a good coat of automotive wax. Of course it would have to be touched up from time to time.
  • jdc1's avatar
    jdc1
    Rockinfigs wrote:
    deltabravo wrote:
    The walls are material called Filon, not gel coat.
    OK.. That doesn't help me with my question
    Replace the whole sheet of Filon ($$$$). I would be more worried about WHY it cracked.
  • Rockinfigs wrote:
    OK but what's the best way to seal it
    More gelcoat, Clean all wax off the surface, then squeegee some thinned gelcoat into the crack.
    allow to harden, buff as require.
  • You may need to drill some small holes on each end of the crack, so it doesn't spread.
