sidney wrote:
I have the Curt X5.
It was the only option we could find at the time to install our Reese R16 Slider in our new 2013 RAM 3500 with a B&W turnover ball .
We towed with it all last summer and it worked great. I was concerned there might be to much play and slop but it was rock solid. I did not need to use any shims... it fit perfectly with no play or rocking.
I have a spray in bed liner... it rests firmly on the bed and did not leave any marks at all where it contacts the bed.
I think the 105 lb weight is the shipping weight that includes all the packaging. I can remove it by myself and does not feel like it weighs over 100 lbs.
It is built extremely well... Being able to remove it from the bed leaving no rails is great.
We are towing a Cedar Creek 34RLSA... GVWR is 14K and our pin weight is just shy of 3000 lbs.
Reese now builds an adapter for the new Rams to use the conventional hitches ,it actually sits just slightly off the bed so there is no worry about messing up a bed liner.
Its very well built, shipping weight was around 90 lbs, and locks down very solid, with no play. Like your adapter very easy to remove for a clean bed without rails.
