Designer 35RLTS and Jayco Talk...Thanks Frank!!
sanderson_66
Since there does not currently seem to be a Jayco owners forum, Moderator Frank has graciously allowed this thread. It will be for discussing Jayco related questions and comments. Anything not Jayco related will be deleted. Sounds more than fair to me. Thank-you Frank!
2007 Dodge Ram 3500 Laramie, CTD 6.7, 6 speed auto,DRW,QC,LB,4X4
2008 Jayco Designer 35RLTS
1,450 REPLIES 1,450
CHV_FRK
You either have a water/air leak or the check in the pump is leaking pressure back. How often and how long does it do that? I can have my pump on the night before, shut it off and go to bed, get up in the morning and turn it on and it won't cycle. So I would say most hold pressure well.
Dana and Natalie
2018 Chevy Silverado 3500HD High Country DRW CC LB 4x4
-60 Aux Tank/Toolbox, Line-X, Full Tint, AirSafe 25K Hitch
2018 Jayco Seismic 4113, 45'7", 17,800lbs w/o the Toys.
M_GO_BLUE1
Sounds like something is leaking somewhere...water pump is losing its built-up pressure and therefore turning on
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
L_MMusic
Has anyone noticed the water pump turning on for a brief moment when no one's using the water? Is this normal or do we have a leak somewhere?
Melissa
Husband Larry
Cocker Spaniel Henry
2008 F-350 Dually Short Bed
Reese 16K Hitch w/ Kwik Slide
Whatever you can do, or DREAM you can, BEGIN it. BOLDNESS has genius, power and MAGIC in it. (Goethe)
loydt
I do have the Mor Ryde so I guess we will see. He can just call me if they dont fit and I will run and get some. I want them back on there.
2021 Jayco Seismic 4212 (on order)
2021 Jayco White Hawk 32BH
2018 Ram 3500 DRW 4x4 CC Cummins/Aisin Laramie Longhorn
BCCDAL
Yes he was probably talking about the spacer kit for the non Mor-Ride suspension.
OT
2006 Dodge 3500 Cummins Diesel,one ton dually,4x4,Jake Brake
2008 Jayco Designer 35RLTS Owen & Phyllis and our Australian Shepard Cody
CHV_FRK
My dealer said something about shock extensions. Was he thinking of the non-Morryde?
Dana and Natalie
cruz
If you DO have the Mor Ryde Suspension, the shocks will NOT be long enough ... this comes from Mor Ryde directly !!
When my dealer did the lift, they are the ones that informed me the shocks weren't long enough AFTER they had already lifted it and tried to re-install the shocks !!
CRUZ
HR & Beth
2006 Chevy Silverado LT3 3500HD, DRW, D/A, CC, LB, 4x4 and RED
Cassie - pure Black Giant Schnauzer
Mollie - pure White Mini Schnauzer (the boss)
BCCDAL
Loydt;
If you don't have mor-ride system the shocks will fit. You need a spacer kit from Jayco for $5.00, order from your dealer. The kit has 8 spacers, 2 for each shock. The Jayco part number is 0088382.
O
OT
eaherrmann
We're Back ๐Ÿ™‚ Wow did we have fun. This trailer is the bomb for dry camping. Everything worked perfectly! We did find the the water pump was a tad bit loud, I'll figure out a new suspension mount that will fix that problem. Genny worked perfectly and we used all of 10 gal of gas the whole 4 day weekend. Here's a picture. Happy Camping ๐Ÿ˜‰
Ed & Elizabeth
Copper
2007 Dodge Ram 3500,QC,LB,DRW,4x4 w/6.7 CTD (BlueTec), 6 speed auto, Factory Exhaust Brake
B&W companion hitch over sprayed in liner
2008 Jayco Designer 35RLTS, Onan 5500, Polar Barrier
Army/Navy retired
loydt
Someone on here said that when you have the suspension lifted the shocks will no longer fit? My dealer says this is not true.
Travlingman
Had my suspension lifted at that time too.
2017 F-350 King Ranch DRW
2014 Landmark Savannah(sold)
2022 DRV Mobile Suite 40KSSB4
cruz
Had mine done at about 1500 miles as well ... same time I had the Moryde Suspension lifted.
CRUZ
HR & Beth
Travlingman
I had my brakes adjusted when we took ours in the last time, about 1500 miles on camper.
whporwil
Do you guys have your brakes looked at or adjusted at a certain point?
CHV_FRK
I too am scheduled for a service visit in two weeks. A small section of a ceiling panel has separated. You may want to check this area as well even though our layouts are a little different.
Our shower skylight is about 8" from a ceiling panel seam. When they screwed in the lower portion of the skylight they really cranked it down in the middle on the side nearest the seam. This compresses the insulation to the point it actually torques the panel to where it wants to bend the panel away from the ceiling. The brads or staples (I haven't pulled the tape) held for a while but I assume being over the shower and a nice warm day aided in the separation.
I would just fix it myself and ask them to provide the tape but I already need to have the ductwork issue resolved so they can take care of it then. Anyway, I would check not only the skylight area, but anything you have ceiling mounted that is close to the edge of a panel. The same thing could happen. I can post a pic if you are interested.
Dana and Natalie
