remdog_1's avatar
remdog_1
Dicor Sealant Removal
I have an issue with coax cable going to base of antenna and I need to remove the base from the roof. It is sealed all around base with dicor sealant.. Any special way I should remove it? I have a heat gun but leery of using it due to rubber roof. Any suggestions appreciated.
  • I have removed dicor from the roof of my trailer and resealed. Used a plastic putty knife and was careful not to tear the rubber roof.
  • I use a plastic putty knife and I am still careful not to cut the rubber. It should come off fairly easily.
