Sgould's avatar
Sgould
Did I screw up my frame?
New to the forum and would like some advice. I recently purchased a fleetwood wilderness 295bhds 32' fifth wheel. I absolutely love the camper, so much so I had the slides out as soon as she was home (in the rain). We are getting snow soon so I wanted to bring the slides in to avoid that whole mess. I wanted to clear the water from the top so I decided to use the front gear to lift her up a tad to make the water run off the slides, controversial I know. So I did so. The only problem is that I forgot to raise the rear stabilizer jacks. When the camper was almost all the way extended it made a loud pop/bang noise. It was hard to tell if it was from the axels, front jack, or somewhere else. I immediately remembered the rear jacks and brought them up. I went on and got another loud crack/ pop this time not as loud. At this point the trailer is not crazy high in the front or anything. The water ran off and I pulled the slides in without issue. No noticeable cracks on the xterior or interior. Also did a quick sweep of the fram pe and it looks ok. I then had to run to work. Needless to say my mind is running wild. I fear that I have damaged the frame or something major. I am hoping it was just a slide adjustment or leaf spring noise? I have no clue really. Do you think I did any real damage? Thx for any help.
Steve G
