Njmurvin
Sep 07, 2016Explorer
Did you upgrade landing gear to Bulldog or Ultra-Fab?
I am looking to upgrade my landing gear to a dual motor setup. After lubing my leadscrew, it works better (no longer trips the breaker or breaks the screw in the cross-shaft). But it still seems like it's straining to lift the front of the rig. It's eventually going to need upgrading. Might as well do it now before it fails entirely.
I've looked at the existing legs and I think I may have an issue. The clamps that are welded on my frame which hold the legs are each 2" wide. They're spaced apart 15.5" inside dimension and 19.5" outside dimension. From what I'm reading, these are not spaced correctly to match the welded tabs on the Bulldog legs. Bulldog wants these brackets 17.5" inside dimension and Ultra-Fab has a couple of spacings to use - neither of which matches mine. If you have done this kind of upgrade, did yours fit the existing brackets or did you have to make modifications?
