โNov-15-2019 10:03 AM
โNov-28-2019 11:37 PM
โNov-25-2019 06:11 AM
laknox wrote:Cummins12V98 wrote:laknox wrote:TazFord wrote:
To help prevent dry rot donโt park directly on soil, asphalt, or concrete. Park on leveling pads or similar
I bought some 2x6 redwood, cut them in half and run my rig up on those. I feel that it bought me time, especially with the first couple sets of China bombs. Always covered, too.
Lyle
Redwood DANG!!!
2 8' lengths at HD weren't bad. Only mistake I made was cutting them =exactly= in half, then screwing them together 2" off center to make a bit of a ramp. Problem is that when you drive off one end, the boards will flip up, catching stuff on the underside of the trailer, like the steps. I =should= have cut the boards 4" off-center so one is longer than the other. So far, they've lasted over 10 years...
Lyle
โNov-25-2019 06:10 AM
JIMNLIN wrote:Rich&Mar wrote:
I'm thru taking the fiver out for the winter. Probably won't go out again for 5 months at least. Do you raise your rv so the weight is off the tires? I never have in the past, but at the price of tires today, I'm thinking I'll start. And do you put a pair of jack stands under each axle? I've read that this might ever so slightly bend the axle when left for months. So where would you put the stand not to do damage?
This was more common years ago when RV trailers were smaller/lighter gross weight.
Many folks also removed their wheels and stored them some where out of the elements. Some also jack some weight off the tires.
We lived in a 31' 5er for 7 months one winter while our house was being built. I leveled the trailer (6" slope in 25') and took frame to ground measurements at all 4 corners. Made cribbing from RR ties and 2" X 4"/etc placed under the main frame rails so the trailer was 2" higher. This took most of the weight off the tires.
I never liked the idea of a RV trailer sitting with jacks under the axles. Not because it does any damage to the axles but JMO some type of cribbing under the frame rails lessons the chance of a wind pushing the trailer off the jacks.
Several ways to store tires on/off a trailer.
My 11k lb 5th wheel RV trailer sits 1 1/2" crusher run for 5 months or so on 2" X 6" boards inside a trailer shed. I keep the tires at max sidewall pressures and jack each wheel 2-3 times a winter and rotate each one 90 degrees so it sits on a different spot. Takes all of 6-8 min.
I've ran nothing but LT tires on my various RV trailers over the years. There good for 6-8 years or 50k-55k miles whichever comes first.
When my equipment trailers sit they have no load. They sit in the tractor barn out of the sun on same type crusher run/wood and always at max psi 24/7 365 days a year.
โNov-25-2019 06:08 AM
Lyle
Redwood DANG!!!
โNov-24-2019 04:56 AM
โNov-24-2019 02:55 AM
โNov-21-2019 12:43 PM
Lyle
โNov-21-2019 08:15 AM
โNov-21-2019 07:42 AM
โNov-21-2019 07:20 AM
โNov-19-2019 11:55 AM
โNov-18-2019 10:08 AM
โNov-18-2019 09:54 AM
โNov-18-2019 08:18 AM
RAS43 wrote:Dave H M wrote:
Would not even think of doing al that horsing around. ๐
X2 In 40+ years of RVing I have had 1 tire failure. Air up and cover tires and park on gravel or old mud flaps is all I do.
