โSep-05-2020 10:30 AM
โSep-07-2020 01:58 PM
โSep-07-2020 01:43 PM
Old-Biscuit wrote:Please cite where that is stated that applies to vehicles other than commercial vehicles.
10 states might not but DOT does
Federal traffic safety law specifies that all trailers that are required to have brakes, shall have a means of activating the trailer brakes under trailer break away conditions
The Supremacy Clause of the United States Constitution establishes that state laws are subordinate to federal laws and regulations.
โSep-07-2020 11:40 AM
Rich&Mar wrote:To keep this thread going for days, I'll ask another question. In researching batteries I read you should let them discharge to 50% before charging. OK, but how do I know when it's down to 50%? What do you do regarding your battery and maintain it in good shape?Thermoguy wrote:Boy are you right. $160. out the door at Schwab, $96. otd at costco.
Just out of curiosity I tried to open my slide yesterday. My battery was disconnected, so I hooked up to power and tried the slide. Wouldn't open. Had to connect the battery just to open the slide.
In WA, Costco, Walmart, Batteries Plus. I don't think Les Schwab would be a good place to get a good price on a battery.
โSep-07-2020 11:31 AM
โSep-06-2020 07:28 PM
โSep-06-2020 06:42 PM
โSep-06-2020 06:27 PM
โSep-06-2020 02:18 PM
โSep-06-2020 12:24 PM
time2roll wrote:This is correct information and common sense.
If the emergency breakaway system was not required it would not be installed on any trailer let alone 100% of them. Trailer would not not even include brakes if not required.
โSep-06-2020 11:31 AM
โSep-06-2020 11:05 AM
Old-Biscuit wrote:Well, the section is for "Subchapter B. FEDERAL MOTOR CARRIER SAFETY REGULATIONS", so again it could be solely commercial, and it isn't the actual government site either. After all the weigh stations post that all trucks must stop, but they are referring to commercial trucks.BarneyS wrote:Old-Biscuit wrote:
If towing you should read up on the FEDERAL MOTOR CARRIER SAFETY REGULATIONS
Break Away and Emergency Braking
It has always been my belief that those regulations pertain to commercial carriers and not to private individuals towing their own private trailers, although many of the the things in those regulations can also be applied to private towing.
I guess what I am getting at is that I think those are possible suggestions, but not enforceable, for private use.
I would assume that there ARE regulations published for private towing, usually on the State level.
Barney
1st paragraph.....
EVERY motor vehicle towing .......
Link on motor vehicle defines what a motor vehicle is. "Motor vehicle means any vehicle.........
It also defines 'breakaway requirements'
Every trailer required to be equipped with brakes shall have brakes which apply automatically and immediately upon breakaway from the towing vehicle...........The brakes must remain in the applied position for at least 15 minutes.
SO the regulation applies...commercial and NON Commercial
โSep-06-2020 10:41 AM
โSep-06-2020 09:47 AM
Thermoguy wrote:Must be your wiring. My slide easily works with no battery. Draws about 10 amps from the converter or the vehicle.
โSep-06-2020 08:45 AM
Barney
