May-23-2018 11:39 AM
May-26-2018 07:05 AM
rconkin wrote:Cummins12V98 wrote:
"Mine came with the hitch from Dodge 25K"
To add a bit more info, if the truck has the prep it's a RAM been so since 2013. Also the RAM hitch is actually a CURT.
Ram Trucks - Wikipedia
Actually Ram since 2010, just to clarify.
May-25-2018 06:05 PM
May-25-2018 05:13 PM
May-25-2018 07:49 AM
May-25-2018 04:35 AM
May-24-2018 07:13 AM
May-23-2018 08:03 PM
mowingman wrote:
Just bought a 2016 Ram with the 5th wheel prep. The puck system is all included, just look under the 4 plastic covers. I bought a B&W hitch assembly just like the one shown above. It hooked right into the factory setup.
The 5th hole, in the middle over the axle, has a plastic cover, but there should be nothing under that cover. It is drilled so you can install a gooseneck hitch of your choice. That type of hitch will require the mounting plates that fit onto the frame rails, then the ball will stick up through the factory-drilled hole. B&W also makes a turnover ball assy. to fit that truck. Then, you could also get the B&W 5th wheel hitch that mounts into the turnover ball socket. If you do that, you do not need the model shown in the above photo.
May-23-2018 04:48 PM
May-23-2018 02:18 PM
May-23-2018 01:38 PM
May-23-2018 12:52 PM
May-23-2018 12:22 PM
May-23-2018 11:49 AM
