slomark
Apr 01, 2014Explorer
Double tow - hitch design
I'm in the process of refining the hitch design between the fiver and the atv trailer. The tv is a Cummins, fiver is 9k#, atv is 3k# tandem axle w/ surge brakes, tw is 300#. Using Reese anti-sway, surge compatible, wd hitch. The small but constant vertical movement at the coupler seems excessive. When considering the distances between the respective axles and the coupler it appears that this leverage point yields somewhat, minor deflection in the receiver mounting plate, I'm using a standard bumper pull receiver rated at 5k#, and tw 500#.
Ideas...
Ideas...
