Jonny8491
Feb 25, 2014Explorer
Double Towing with my rig (pics updated 5-13-2014)
Do any of you have pictures of the towing hitch on your 5th?
Mine is welded to the frame at 2 seperate locations, with triangle supports welded on either side. I am hoping to figure out if this is beefy enough to haul my 18ft fiberglass boat(3500lbs).
also,
this is my set up, any concerns would be appreiciated.
2012 2500HD Chevy standard box 6.0L gas...6500lbs....20ft long
2004 Dutchman 24G-M5.....7300lbs....tip to tip 29ft long
2004 618T Ranger...3500lbs....22' length with trailer
20K curt hitch
GCWR of the truck is 20,500lbs
GVWR is 9500lbs
MN state law says 70' is ok
thanks much
Jon
also,
20K curt hitch
GVWR is 9500lbs
thanks much
Jon
