Electric over hydraulic brakes
DRVMN
Just bought a 2013 Elite Suites 5th wheel that has electric over hydraulic disc braking system. Pulling it with a 2017 F350 Super Duty.
When applying brakes with the hand control at full power I am getting very little braking.
Does anyone know if there is any power adjustment on the brake actuator that is located on the RV? Or any ideas how to increase the braking power applied to the trailer brakes? As I mentioned earlier the power setting on the brakes controller in the truck is set at max (10)
25 REPLIES 25
Cummins12V98
eHoefler wrote:
Cummins12V98 wrote:
"It is very unlikely that they need to be bleed if the resevoir is still full and there is no signs of leaking."
Have you ever owned a new DRV?
Does not really matter. Hydrualic disc brakes on anything are all about the same, they operate the same whether they are applied by foot, air or electric pump.
YES it does matter! I have owned DRV's and my 16 needed to be bled and many others have also. There is one reason, it's the LAZY people doing the job in the first place. Has NOTHING to do with the system.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Fulltimer50
Note that on my 2011 F350, the trailer brakes do not work unless the truck is going more that 5 mph. This may have changed over the newer years. The emergency brake switch on the trailer is the only way to activate the brakes.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
eHoefler
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Cummins12V98
lee_worsdell
I have mt setting at 4.5 and still lock up the rear axle some times. Having brakes looked at next week
eHoefler
Since it has sat for 3 years, there is rust on the rotors that has to be removed/worn off and/or the pads need to be replaced. It is very unlikely that they need to be bleed if the resevoir is still full and there is no signs of leaking.
DRVMN
It's going to be a couple of weeks before I can get back to where the trailer is to deal with this. I appreciate everyone's input and ideas.
A couple of things I can comment on now though. Ford confirmed the controllers in the 2017 Super Duty trucks work with all major electric over hydraulic actuators. It was noted that the braking signal was influenced by both speed and brake pedal pressure.
This unit has sat for 3 years in storage so I can guess that bleeding the brakes is a excellent idea then trying the brakes both with the truck controller and the breakaway control and see if there is any difference. Checking the brakes with the wheels off of the ground does not give a realistic test to the brake since you have no load resistance so I will do it on the ground.
I will update after I get my hands back on it.
Thanks
GoPackGo
One more thing you could do is to disconnect the trailer from the truck and jack up a trailer wheel. Just get it off the ground so it freely rotates. Then pull the emergency disconnect pin on the brake system. This should lock up the brakes. Then check to see if you can rotate the wheel.
You must have a good battery installed to do this.
GoPackGo
One more thing - I have a 2013 F350 and had disc brakes added to my fiver last spring. As was explained to me by the installer, the Ford system does not send a strong signal to actuate the trailer disc brakes very much until you are moving at a much faster rate then walking or idle speed. So make sure your truck is set to the electric over hydraulic setting and then hook up and try it at about 25-30 mph, then at highway speeds. I have my gain set to 6 and that works well for me, but thinking of going to 5 to see if it's easer to modulate braking. Mine stops quickly enough if I stab the pedal that I am a little worried that the car behind me could run into me.
My truck did not need the module discussed above.
time2roll
Do you even hear the pump running with the brakes applied?
Learjet
Cummins12V98 wrote:
^^^^^ Depends on the the year of truck.
yes, I KNOW that! the person saying you need a part didn't specify that. That is why I stated the year of my truck for reference.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
Cummins12V98
Learjet
eHoefler wrote:
Ford and GM need a brake control module for the electric pump to work properly. Check with the Titan website for the module
https://www.etrailer.com/Accessories-and-Parts/Titan/T4846000.html
are you sure about that? My 2013 F250 worked fine with the Elec/Hyd setting.
B&W Ram Companion
eHoefler
