Recently replaced all tires, truck & trailer, and have noticed a slight fishtail effect at higher speeds 55-65 MPH.
The 'type' of tread is what causes tire roll on any heavy vehicle.
Too aggressive of a tread, and the outer one flexes. Take two fingers and see if you can move the tread back and forth easily on the outer tread of your 'new' tires. If you can there's your problem.
Amazing what just a small amount of flex can do even on the non steering FW. Henceforth why semi front tires have a bald flat slick for an outer tread.
Been there done that.
I screwed up a perfectly handling MH when I put too aggressive tread Mich's on it.:(
