Aug-12-2017 07:33 AM
Nov-15-2017 08:34 PM
Durb wrote:Cummins12V98 wrote:Durb wrote:
I can't understand all the objections to bed rails but then my truck is not a gravel hauler. You can get a Bed Mat by BedRug and cut out openings for your rails. The mat thickness is the same as the bed rail height and when loading stuff it slides right over the bed rails. It is also very easy on the knees. Just an option.
If you used your truck as a truck you would understand!
Interesting comment from someone with a truck box taking up a quarter of his bed. Tell me how easy it is to shovel out a load of 5/8 minus with that box going down to bed level.
Fact is, when I need gravel, bark, rock or topsoil I have it delivered. My truck swallows up a lot of lumber, plywood, landscape stone and occasionally furniture. Neither the BedRug nor rails have ever been an issue. I use my truck plenty.
Nov-15-2017 08:17 AM
Nov-14-2017 06:02 PM
Cummins12V98 wrote:
You will NEVER regret owning anything with the B&W name on it. US Made MOST of the others are NOT as in REESE and CURT.
Simple solid design no silly color codes or flimsy latches.
Nov-14-2017 07:07 AM
Nov-14-2017 03:09 AM
Nov-14-2017 03:08 AM
Nov-13-2017 07:18 AM
Nov-13-2017 05:51 AM
Nov-13-2017 04:37 AM
Nov-12-2017 07:52 PM
Nov-12-2017 07:16 AM
nu2this2 wrote:
I recently switched to the Andersen ultimate 5th wheel hitch. So smooth when pulling, no clanking very easily installed and removed. It only weighs a bit over 30lbs. I had a Reese slider and had to use a hoist to remove it,because of this it stayed in the bed of my truck all the time! The Andersen can be removed in less than 3-4 minutes. I kid you not!!
If you get one you will not be disappointed .
Nov-11-2017 03:49 PM
Nov-11-2017 10:04 AM
Aug-28-2017 12:56 PM
Big1 wrote:
I have the B&W with the turnover ball I love it, it seem to be very solid and as far as putting it in my bed I bought a $99.00 discount 1 ton engine lift and it work for me.
