โMay-24-2023 09:22 AM
โJul-28-2023 02:56 PM
Cummins12V98 wrote:
They are still having issues. Look at the youtube video "Why We Ditched The Andersen Hitch".
I did s simple search "Andersen Ultimate 2 hitch failures".
โMay-30-2023 10:46 AM
โMay-29-2023 02:37 PM
โMay-29-2023 07:54 AM
โMay-28-2023 07:58 AM
โMay-28-2023 06:31 AM
Cummins12V98 wrote:cummins2014 wrote:Cummins12V98 wrote:
EASY!!!
It's your CURT hitch. Look at how low the pivot point is on the CURT. FACT it can cause a chucking feeling.
Compare to the B&W that has it's pivot point at the height of the kingpin.
What took you so long . It's sure possible it's the hitch . He is a great candidate for the Andersen , and IMO would solve his problem . I am sure you will agree on the Andersen with the weight he has , no need for some expensive hitch .
If they made it to attach to the pucks instead of relying on thin beds to support the fore and aft and make the tubing stronger I would consider it for a 12 RV.
YES the CURT can cause a chucking sensation that's a fact.
โMay-27-2023 09:10 PM
Krusty wrote:
Sounds like it could also be a driveline shudder. Some trucks are more prone to it than others, depending on driveline type, wheelbase etc. They are fine at normal ride height until a load is applied and it changes the u-joint angles enough to create a shudder felt on accel from a stop.
โMay-27-2023 04:45 PM
EASY!!!
โMay-27-2023 09:54 AM
โMay-27-2023 09:36 AM
โMay-27-2023 03:45 AM
Cummins12V98 wrote:
EASY!!!
โMay-26-2023 05:46 PM
โMay-26-2023 12:03 PM
Part-Timer wrote:
I have entertained the idea of the Andersen goosneck adapter. Hard to convince the wife of the cost when I have a "perfectly-good" hitch now. I like the convenience idea of the Andersen and the light weight in/out removal concept especially compared to the 200lbs of cast iron that I have to deal with now. But I'd hate to spend the money just to have the same jerking that I'm feeling now. As for normal "chucking" common to fifth wheels... I really don't have any to speak of. It really does pull and track well and the handling is great. Just this tugging sensation when accelerating at certain rpms is mind boggling.
โMay-26-2023 11:49 AM
