Dayle1
Feb 21, 2014Explorer II
wmiller2502 wrote:
I've read some but I was hoping to hear from people who use this setup and have had good luck. I just can't see how it puts anymore stress than hooking up to a fifth wheel hitch.
Just because you can't understand it, doesn't make it true. Look on page 65 of the Feb. 2014 issue of Trailer Life and read what PopUpHitch states. If they recognize that some frames aren't strong enough (and Andersen hitch knows it too), they must recognize something that you might be missing. And since they can't supply a list of OK vs. weak frames, then it is entirely your guess about risk.
Other than the already mentioned Goose Box, if a GN adaptor is absolutely needed, then the Andersen Ultimate hitch is the safest answer (and likely why Andersen introduced it). With the ball just a few inches from the king pin, it puts far less stress on the fifth wheel frame. And since the ball is elevated, it is much easier to see from the driver's seat. Andersen also claims it doesn't need safety chains, but you should check with your state authorities.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
