Oct-27-2022 03:59 PM
Nov-02-2022 01:03 PM
tourusa wrote:
Nov-02-2022 08:55 AM
Nov-02-2022 07:00 AM
schlep1967 wrote:
You are still measuring from the puck mounting point. Watch the video I posted again. You need to measure from where the center of the pin would be to the closest point on the cab. Or in your case the closest point on the corner of the tank.
How high does the tank sit above the top of the bed?
Nov-02-2022 06:41 AM
MFL wrote:tourusa wrote:
Based on the recommendation of the B&W hitch which installation would you all suggest based on my setup
Normally, with a long bed truck, I'd suggest putting the arms in the farthest forward (3"s ahead of axle).
If you still have the fuel tank installed, with a certain amount above the bed rails, you may want to allow more clearance, so arms installed to rear position (1" ahead of axle center).
In any case, since you don't have a FW yet, to know how much clearance, you need to set the hitch to a height that will likely give 6"s bed rail clearance minimum. Center height, or highest height, would be best starting point.
The B&W hitches are easy to readjust, once you get the FW home, or even on site at the place of purchase, if you have just a few tools with you.
Jerry
Nov-02-2022 06:33 AM
Nov-02-2022 04:23 AM
Nov-02-2022 04:01 AM
tourusa wrote:
Phew, I’m getting into the new concept from trailer to fifth wheel ,
I do have a question do you guys see a difference between towing a 36 ft and a 44 ft forth wheel, we are hunting around and I know the truck no problem ??
Nov-01-2022 06:10 PM
Nov-01-2022 05:11 PM
Nov-01-2022 05:10 PM
Nov-01-2022 05:08 PM
Nov-01-2022 05:03 PM
Oct-28-2022 06:07 PM
schlep1967 wrote:
The fuel tank could definitely stay. Your concern would be the tool box. If you could cut enough off of the bottom of that to get you to bed rail height you could keep it with a standard hitch. If you remove the tool box you can use a standard hitch.
If you want to keep everything the way it is I would consider an autoslider hitch. The length of your fifthwheel makes no difference. The width is what matters. When you turn 90 degrees half the width of the trailer is going to be in front of the pin towards the cab, or in this case towards the tool box.
Oct-28-2022 06:06 PM
