โOct-01-2018 08:05 AM
โOct-07-2018 06:59 AM
โOct-04-2018 10:30 AM
โOct-02-2018 07:49 AM
smarty wrote:Then page 8 directs you to take off the facia on the outside of the slideout. Don't know how big yours is, but you would probably want to talk to someone that has done it before to get a general idea of what to do to take it off and put it back on again.troubledwaters wrote:
Did you read the instruction about pushing the mode button 6 times than pressing and holding it the seventh time until controller goes into override mode? Page 7 Here!
Yes, tired this a few times with no luck
โOct-02-2018 07:26 AM
โOct-01-2018 01:15 PM
โOct-01-2018 12:53 PM
bgum wrote:
You may have a pin you can pull to delink the motor. For all the troubles slides present they just aren't worth it.
โOct-01-2018 12:49 PM
newman fulltimer wrote:
Plug the motors back in find the controller hit the small black button on the controller for a few seconds this overrides the system then you can move it out
โOct-01-2018 12:48 PM
BarneyS wrote:
There is usually a manual crank position somewhere to crank out the slide. It would help if you would post the make and model of your rig so members could help you out better. Just click "edit" on your post to add that information if you can.
Barney
โOct-01-2018 12:47 PM
โOct-01-2018 09:55 AM
โOct-01-2018 08:55 AM
โOct-01-2018 08:51 AM
โOct-01-2018 08:39 AM
โOct-01-2018 08:09 AM
