Flat spots on front axle tires
Texas_Two_Stepp
Since I bought my 2013 Excel I have been having problems with flat spots on the tires on the front axle. These areas are about 10โ€ apart with one usually being worse than the others, and worse on the curb side. I have bought 3 new tires over the past two years because of this. The tires are 17.5 Michelin load J and are expensive. The undercarriage, calipers etc. are Dexter. Total trailer weight 15.5k with app. 6k on each axle. I have recently learned that the problem may be related to the braking rotational force exerted from the rear axle thru the equalizer bar causing a slight lifting force on the front axle and causing those front tires to skid. I think the cause of this may be from two things: being slightly nose high (I do this to get about 7โ€ clearance above the bed rails) would cause a little more weight on the rear wheels when braking and being heavy on the drivers side (2 slides, 4 batteries and refer. vs 1 slide on curb side). I set my brakes by the prescribed procedure and run air pressure per tire charts.
I do not know how to solve this problem except buying new tires. I do have 3-3 position spring hangers(?) on each side which are all set in the highest position. I have been thinking about lowering the front 2 hangers on each side to the middle position but donโ€™t know how that will effect things.
Your input will be appreciated.
2015 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
16 REPLIES 16
chrizg
Are you locking up the tires when braking but not realizing it ? My trailer brakes become more sensitive as they heat up.
23 Rockwood 2608BS
22 Dodge 3500 Crew SRW
Old
16 365 Landmark Charleston
06 Dodge 3500 Mega Cab 4X2 DRW B&W
16 Dodge 3500 Crew Limited DRW B&W Aisin 4.10
K_Charles
you say nose high, how much too high?
