rhagfo
Sep 27, 2016Explorer III
Texas Two Steppers wrote:
I do not know how to solve this problem except buying new tires. I do have 3-3 position spring hangers(?) on each side which are all set in the highest position. I have been thinking about lowering the front 2 hangers on each side to the middle position but don’t know how that will effect things.
Your input will be appreciated.
I assume the by "the highest position" you mean the position the has the 5er as high as possible at the axles. If by "the highest position" you mean the set of holes nearest the frame, then why not move to the holes furthest from the frame.
Unless you are near 13'-6" at your highest point I would be working to get the 5er as level as possible.
![](http://i1191.photobucket.com/albums/z467/rhagfo/Copper%20Canyon/EBCA8BF6-58D1-4A57-A30C-2BAAC9CF23CB_zpst7radrhw.jpg)
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
