Flipping Axles?.....Well kind of
fivecodys
I have a Flagstaff 8528RKSS.
With my current truck I have almost 6" of clearance between the bed rails and the trailer.
This is with the pin box adjusted to it's lowest position.
I am looking at new 3/4 or 1 ton trucks.
I have noticed that the bed rails of these new trucks are significantly higher than my current truck's rails.
This causes me great concern and I do not want to be in a 'nose high' towing situation with less clearance than I have now.
So here is my question;
Is there a way to raise the height of the trailer?
I have Dexter torsion axles so I don't see a way to do an 'axle flip'.
A new fiver is still a few years away so I need to come up with a solution for now.
Any ideas?
Many thanks.
Bill
2007 Tundra DC 5.7L V8
SuperGlide 14K
Prodigy Brake Controller
2009 Flagstaff 8528RKSS Ultralight Series
Air Lift 5000
We have enough youth.......... how about a fountain of "smart"? :S
12 REPLIES 12
fivecodys
jaycocamprs wrote:
Look at the Dexter Axle Torflex Lift Kit page. They may have what you need.
You guys sure are smart!
Thanks for the links.
This forum is a tremendous resource!
Thanks again to all who replied.
Bill
SuperGlide 14K
Air Lift 5000
alfresco
when I changed trucks from a 97 1500HD to a 07 2500HD there was 6" difference in height. I had a local machine shop install a 6" wide steel tubing between the frame and spring hangers. Did the job fine.
About $900.
Patti & Ron
07 2500HD 4x4 Silverado
23' Hornet 5er
Newblue
I ended up lifting my torsion axle trailer 4" to keep from scraping the rear end. I don't trust my own welds to have 10 tons rolling down the highway on them so I took it to a semi frame shop to be lifted.
JIMNLIN
http://www.dexteraxle.com/inc/sdetail/45177/45180
This may or may not work. Give Dexter a call with your problem
jaycocamprs
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Dayle1
I did this on a previous trailer with torsion axles. I was able to buy a 'lift' kit from the trailer manufacturer, so you might give Forest River a call. Anyway, the kit had two rectangular steel tube about 5 ft long and four predrilled steel plates. Cost was less than $200, but that was a number of yrs ago. The tubes provide the lift and the plates weld between the frame and the tube, but they extended below the tube to provide bolt locations for the axles. It is important to note that you cannot weld directly on a torsion axle, the heat will degrade the rubber inside the tube.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
fivecodys
Rbertalotto wrote:
No spring hangers with torsion axles.........
You need a welder / machine shop to make a couple of riser blocks.....
Don't listen to the "No 4WD" advocates......When you need it, there is nothing like it!
There is a trailer repair place in Fresno. They do mostly Commercial trailers but I will see if they could handle this and make sure the trailer axles are aligned properly.
I'm sure it won't be a cheap solution.
Many thanks,
Bill
SuperGlide 14K
Air Lift 5000
Rbertalotto
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
chipper
Remove the spring hangers from the frame, weld a square tube of the appropriate size to the frame to raise the axles,reinstall new spring hangers. This would need to be done by a professional who knows what he is doing.I have seen a couple of units that this done & it fixed the problem very well. They probably would need to weld in a couple of cross braces to stiffen the finished product.
gene
Peg_Leg
You can have a metal fabrication shop make a sub frame with thick wall tubing to lower the axles.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Ed9824v
my boys bed is 3 in taller on his new ford compared to my 98 dodge we just put the hitch in SuperGlide and I ordered a 3" lift for the hitch today to have clearance above the side rails.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
john_bet
My suggestion would be not get a 4wd as they are higher than a 2wd. My '04 truck is less than 2" taller than my brothers '85 1 ton cc on the same brand, but a 4wd like mine is almost 5" taller than mine. Just info.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
