Travlingman
Feb 20, 2015Explorer II
rockhillmanor wrote:I haven't had water all day because my line must have froze and so after lugging jugs of water back and forth in order to do dishes I notice my sewer hose is now frozen. Any advice on what to do would be greatly appreciated.
WHY are you leaving your black tank sewer blade OPEN?
Whether you are just RV'ing or 'living' in your RV you leave the black tank closed. Let it fill to 3/4 and then dump.
The reason your sewer hose is frozen is because there is waste just sitting it in, now frozen.
Waste needs WATER to move. That also means there is most likely a mountain of poop in your black tank also.
Leave black tank closed when 3/4 fill dump. That water takes all of it out and completely down the sewer hookup. NOTHING should be in your sewer lines.
Frozen water line:
In freezing temps you need to:
Disconnect water hose from spigot and your RV.
then Drain the water hose.
That way come morning when the temps rise you just reconnect the hose and you are back in business.
Where did the op say the black tank valve is open?
OP, is it your hose that is froze up, water spiqot or is it froze inside the camper. If in camper, you can turn furnace up or put a heater in basement to help it warm up faster.
As far as the sewer hose, make sure you have a good drop angle from camper to sewer outlet. To unthaw, put hot water down hose to thaw out.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 26, 2025
