lincster wrote:
tinner12002 wrote:
lincster wrote:
Yeah, bikes on these forums, folks usually think of dirt bikes.
You won't get 2 golf carts in a 10' garage.
Why not if they are under 48" wide, should be able to get them side by side. The OP would need to measure the inside width of the toy hauler he's considering and then measure the width of both golf carts in use.
96" wide?
My door opening is only 96" wide and then it is only 2" to the wall.
Good luck on getting 2 of them up in there side by side.
I don't think they will fit.
Dimensions aren't always the only thing to consider.
Once you get 1 machine in there, can you maneuver the 2nd enough to get it in there?
Not like you can drive them both straight in and call it a day.
I understand what your saying and that's why I said he needed to measure both to make sure he had the room to get them in side by side...didn't say it wouldn't be tight.
