RobWNY
Aug 22, 2018Explorer
Gel Coat Cracking
On my new 5th wheel, I have an area on the nose where there are spider cracks. There is also a slight bump where the cracks are. Obviously when the manufacturer installed the nose, it came in contact with something from the back side causing this issue. You can't feel the cracks when running your fingers over them but I worry about them becoming larger as stress occurs while rolling down the road. Is this something I should get repaired under the warranty or is it cosmetic and nothing to really worry about. You can't even see the cracks from the ground. I only discovered them when I was waxing the nose. My main concerns are the cracks expanding or enlarging as stated earlier and water infiltration in the future.
![](https://i.imgur.com/t0VVFjEl.jpg)
