klr650goldwing's avatar
Mar 08, 2020
Grand Design slide out malfunction
Our slides will not extend. The battery is new. The manual says to check the auto resetting fuse, which is located next to the slide out motor. But I don't know where the slide out motor is located on this 369RL. CAN ANYONE HELP ME OUT?
  • Is it a rack and pinion type s/o? If so, the motor isn under the rig.
    The main slides on the Solitudes are hydraulic.
    Rob
  • klr650goldwing wrote:
    Thanks for the help. We found a blown 15 amp fuse. Changed it and all is well.
    Glad you found it. Now the question is why did it blow?
  • 15A seems smallish. If it blows again after several cycles, I'd up it to a 20A.
