Garyl53
Jun 24, 2016Explorer
Harsh ride & chucking…please help me figure it out! (Long)
Hi,
Here is my current truck and trailer info along with suspension enhancements:
2011 F250 Super Duty, 6.7L PSD, CC, SRW, Camper Package, Snow Plow Prep Pkg. with Lower & Upper Stableloads, new Bilstein 5100 shocks, Husky 16K W hitch (Center line of king pin about 4” ahead of axle)
2007 Keystone Challenger 29RKP with Reese Sidewinder (SWW-04 wedge for Husky hitch), Dexter EZ-Flex, Lippert Shock Kit, Lippert Correct Track II (recent professional alignment done), new tires
Here are my CAT scale results:
F250 6.7L PSD 4X4 Lariat - Full tank, Husky 16k W hitch, me:
Steer Axle - 4720
Drive Axle - 3300
Total - 8020
With 2007 Keystone Challenger 29RKP under tow:
Steer Axle - 4740
Drive Axle - 5980 (vehicle total=10720)
Trailer Axles - 7780
Total - 18500
Trailer:
Pin Weight – 2680 (25.6%)
Axle Weight - 7780
Total - 10460
About 700 over published tow vehicle GVWR (10000) but...
1320 under axle ratings 5940 (FGAWR) + 6100 (RGAWR) = 12040) and 5000 under GCWR.
I purchased this 5th wheel and truck (used) last summer but despite several suspension improvements on both truck and trailer I continue to experience severe chucking. I am using the term “chucking” here to mean the feeling of a push/pull (or forward/rearward) motion on the truck which creates a very uncomfortable ride. The chucking is always present with the exception of climbing a steep grade (>4 percent) but of course it varies substantially in intensity depending on road conditions, road slope and speed. It does not appear to be directly related to road conditions as it can become severe even when driving on flat and very smooth newly paved asphalt roadways at speeds between 50 and 65. A recent 150m trip had very severe chucking (the FW tank was empty) but that night I fully filled the 50 gal. FW tank (located just ahead of the front axle) and it reduced the amplitude of the chucking somewhat but it was still very much present the next day and still very uncomfortable. I adjusted the pin box to level the trailer frame within 1” front to back. I checked the king pin movement in the hitch and it appears to be minimal (< 1/4 in.). I even operated the Sidewinder pin box in a fixed configuration (service bolts installed) just to eliminate that factor but no change. I added shocks to the trailer which I could visibly see made a huge improvement in the ride of the trailer itself and I had the trailer axles aligned by a professional shop but this had little or no effect on the chucking. At this point I don’t know what to try next. I know there is the option of an air or rubber pin box or an air hitch but my gut tells me there is something wrong with the set-up and I am not convinced I wouldn’t be just covering up a problem or risking a fair amount of cash without fixing the issue. I also realize I am a bit over the GVWR of the truck but there appear to be many, many RV.NET members running similar weights that don’t have this issue.
- Should I try adding additional weight to increase the pin weight more even though it is already 26%?
- Is there too much pin weight? Can I load weight in the rear to see if this helps?
- Is it the truck or trailer causing the issue? How can I determine? Could it be a truck suspension issue?
- I am riding on the truck overload springs when loaded… should I opt for air bags instead?
- Can the Husky Hitch be bad? What else should I check? (All bolts have been torqued to specs)
- Is it just a bad combo of truck and trailer?
- Picture
Any and all suggestions are very much appreciated and I will report back any results. We can’t live with this as it is for anything longer than a few hour trip.
Thanks in advance!
Steer Axle - 4720
Drive Axle - 3300
Total - 8020
Steer Axle - 4740
Total - 18500
Trailer:
Axle Weight - 7780
Total - 10460
- Picture
Thanks in advance!
