Heat setting off smoke alarm
way2roll
Navigator
Navigator
First time trying the heat in the new FW. I expected a lot of "new" smell, what I didn't expect was that it would set off the smoke alarm. I don't remember this ever happening in any of our other RV's despite them being new also. There was no visible smoke and I shut it down. Part of me wants to chalk it up to never having been used yet, another part of me thinks there could be some debris in the burner that could be a real danger. I thought I might try it again this weekend with the windows open to let it burn off any "newness". Thoughts?
Jeff - 2023 FR Sunseeker 2400B MBS
6 REPLIES 6
cavie
remove the detector and burn off the junk in the furnace.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
way2roll
Navigator
Navigator
Thanks, confirms what I was thinking.
MFL
Nomad II
Nomad II
I've also had the smoke smell with new furnace, but never set off the alarm. I agree with others. The difference could be the higher quality/accuracy of the alarm, or the close proximity of the furnace to alarm.
Jerry
midnightsadie
oils off the new furnace burning off , run it for a few hrs it,ll be gone.
^^^ I agree with the above ^^^
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
DownTheAvenue
Yes just run it about two hours. I bet your problem is then solved.
