โJun-01-2016 03:58 PM
โJun-02-2016 08:59 PM
transamz9 wrote:Me Again wrote:
Just for the record cummins12v98 dies have experience with hitches that put the pin weight on the bed floor with his 2011 and B&W Companion that caused some deforming of his bed.
I might consider a rail mount version on my Demco 6099 picture frame, however not the version that carries the weight on the bed floor. Chris
When you haul a rock quarry in the front of a 5er you are going to be heavy.
โJun-02-2016 07:36 PM
โJun-02-2016 06:35 PM
โJun-02-2016 03:39 PM
โJun-02-2016 02:49 PM
vort max wrote:
I prefer this discussion now to wander too far off topic.
A reliable dealer here in Oregon says they don't recommend an Anderson hitch with a short bed while another says there will be no problem. Of course, neither will guarantee anything. My concern is how sharp a turn can I make before getting into trouble?
The Anderson ad video actually shows a Couger 5th wheel in a tight turn not hitting the cab which leads me to believe it will work.
I am also hoping the Anderson hitch will be easier to back up then the Pullrite superglide hitch. (I have a 10X30 ft driveway I must pull into on a narrow street and the superglide, at least for me, requires too much jockeying.)
โJun-02-2016 02:41 PM
โJun-02-2016 01:40 PM
โJun-02-2016 01:19 PM
fj12ryder wrote:
Cummins12V98 doesn't like the Andersen hitch. You'll just have to learn to live with that. Arguing isn't going to change his mind.
โJun-02-2016 01:13 PM
fj12ryder wrote:What it will do is get the thread closed.
โJun-02-2016 11:50 AM
โJun-02-2016 11:47 AM
WTP-GC wrote:Cummins12V98 wrote:
Under 12 K Andersen is no doubt an option. Towing heavy not so much. Bed deflection and bent tubes. They have updated for those towing heavy.
Andersen rates their hitch at 24K, but you're saying that the hitch is only good for less than half that. Why would they rate it so high then? Wouldn't they be held liable if someone experienced a catastrophic failure as a result of their hitch being overrated? I searched long and hard but couldn't find more than a one case of bent tubes, and only a few other comments from dissatisfied customers. You must have some engineering data or information regarding a high number of incidents to confirm your position.
โJun-02-2016 10:38 AM
โJun-02-2016 10:08 AM
โJun-02-2016 09:48 AM
โJun-02-2016 09:05 AM
Dumoldles wrote:
Andersen hitch is great, I have a short bed truck and no problems. I got it because I can easily, within two minutes, take it out of my bed and store it in the storage compartment of my 5th wheel. Difficult for me to fathom why anyone would go with your traditional heavy, clunky hitch...hope I didn't any of old school guys.
Dumoldles
