Help- we found crack in frame
Brundo
We were going to reinforce the frame on our fifth wheel. After some of the paint was off. we found crack in the frame next to pin box on front cross member. Has anyone had this fixed? Where did you take it and how did they fix it? How much did it cost? Would appreciate any info you have.
Dodge 3500 Ram Diesel
21 REPLIES 21
richfaa
Lippert builds over 60% of all frames so they may have more problems.
2013 Montana 3402 Big Sky. 08 Ford F-350 6.4L
azbohunter
n7bsn wrote:
As for frequency, it certainly appears that Lippert frames get more repairs then any other, as frame issues with the firms that use someone else are rare.
Lippert may have more but not sure that others are rare??
2006 Dodge Quad Cab Cummins 5.9 Automatic 4x4
2002 28RKD Lakota fifth wheel
Pullrite Hitch
2006 Polaris Ranger
16'Lund w/50HP Merc tiller
A great wife who loves to travel and fish
I love to archery hunt/she joins me and cooks!
n7bsn
RamTX wrote:
Last year we found cracks on both frame rails under the axles on our 5er..... I had previously contacted Lippert about the cracks, and they sent me repair instructions. ..... Apparently, cracks in trailer frames are not totally uncommon....
Good plan, go to someone that knows what they are doing.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
n7bsn
FishOnOne wrote:
You may check into the nearest Camping World or Holiday World.
Good luck...
For what? a reference to a shop that specializes in frame repair?
FishOnOne
Good luck...
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
donn0128
Yea, find a large commercial trailer repair shop. It might cost you a few dollars but the quality of the repairs will be well worth it in the end.
RamTX
Last year we found cracks on both frame rails under the axles on our 5er. Took it to a trailer repair facility which repairs large commercial trailer frames. I had previously contacted Lippert about the cracks, and they sent me repair instructions. When I showed the owner of the trailer repair facility the cracks, he recommended repairing it virtually the same as Lippert. So I felt reasonably comfortable in what they were going to do. They repaired it for a reasonable cost and in only a couple of days. Apparently, cracks in trailer frames are not totally uncommon, so I thought it was best to go with a repair shop that did such work day in and day out.
2005 Dodge 2500 CTD ShortBed Quad Cab
08 Jayco Eagle Superlite 31.5FBHS
Line X
Superglide Hitch
Prodigy Brake Controller
