quentinlindsay wrote:
Tow rating for the truck is 17000lbs and change,
quentin,
this statement is an example of why it's important for you to educate yourself on towing and weight capacities. What a truck can pull is usually the least limiting of the considerations. The most limiting is usually what the truck can carry.
Many folks have chimed in on this thread to give their insight on towing considerations for your setup. Some are contradictory with others and that's usually the case for these 'weight/towing' threads. So that leaves it up to you to sort thru all the info and make a conclusion. Without the knowledge of towing and weight capacities you'll just go off of what sounds good or what would work with your setup based on what someone said. Not trying to be a harda** here, just tryin to emphasize the importance of someone being able to make an EDUCATED decision when it comes to towing these large trailers.
