โMar-21-2019 08:16 PM
โApr-08-2019 08:57 AM
Me Again wrote:cummins2014 wrote:
This guy on youtube went one step further he added a switch ,where I added my gas shutoff valve, but wired in the switch ,so he could switch to where the generator remained running until it ran out the gas in the carburetor , or where when he shut it off it quit to add gas. Switch or gas shutoff valve , take your pick.
For me if I would of known , I would of done neither. As often as I winterize mine, I would of taken that front cover off unplugged that connection , and let it run until the carburetor was empty ,and it stopped running .
The did that on our eu1000i, disconnected the run switch from the OEM knob and wired another switch next to it. So I could turn off the OEM knob and let it run the carb dry. Have to do it to our eu2000i.
โApr-06-2019 03:36 PM
โApr-05-2019 08:54 PM
โMar-28-2019 05:39 AM
golf_bears wrote:
The fuel jet is probably gunked up. You need to remove the carburetor, pull out the fuel jet and clean it.
โMar-27-2019 01:20 PM
I have used seafoam, its a great stabilizer , I guess. Nothing replaces shutting off the gas ,and running until it quits. No gas in the carb equals no problems
I have a 28 year old Honda lawn power, , and I have done this for 28 years, I leave whatever gas is in the tank, turn off the gas , run till it quits. Top off the gas with fresh in the spring, and it fires on the first one or two pulls, and runs as good as the day it was bought. I do the same with all my small engines.
The way Honda builds the switch into the fuel valve one can not do that. I took my eu1000i apart and did that years ago. Sold that and have an eu2000i that I have not yet added an off/on switch separate from the fuel valve. Chris
โMar-27-2019 12:51 PM
โMar-27-2019 12:06 PM
โMar-27-2019 10:24 AM
Lynnmor wrote:Tvov wrote:
bombero, I guess I'll write some bunk and am 15 years old... I've had similar experience as Lynnmor running lawn mowing / landscaping equipment.
BEST thing I've found is to run equipment regularly (don't let is sit longer than a month). For long term storage, drain the fuel tank and run the equipment to use the fuel left in the carb. Sure, go ahead and use additives all you want, just be careful depending on them.
Thank You.
I try to run or drain them dry as well.
โMar-27-2019 05:33 AM
โMar-27-2019 05:03 AM
โMar-26-2019 04:02 PM
Lynnmor wrote:
I have 32 carburetors to deal with on my vehicles, tractors, generators, outboard and lawn & garden equipment. I do all my own engine work and have used exactly one can of Seafoam in my life. That can didn't seem to do a darn thing. If there is junk in a carb, the gasoline will wash it out eventually or physical removal is required, IMHO.
โMar-26-2019 03:17 PM
โMar-26-2019 12:24 PM
jkwilson wrote:babock wrote:
LOL...do not add Seafoam! Do not add a snake oil. If it's new, take it to your dealer for them to determine why its running lean.
Seafoam is an excellent product. It doesn't work magic, but it routinely saves tearing a carburetor apart in engines that have been sitting.
โMar-26-2019 10:47 AM
dieseltruckdriver wrote:
I should add, I also only use non ethanol premium in all my small engines.
As far as Seafoam being snake oil, I used to think that too. If you obviously haven't tried it, don't knock it. I used to make fun of it too, and got proved wrong. I am not a big fan of crow.... ๐
