Me Again wrote:
cummins2014 wrote:
I have used seafoam, its a great stabilizer , I guess. Nothing replaces shutting off the gas ,and running until it quits. No gas in the carb equals no problems
I have a 28 year old Honda lawn power, , and I have done this for 28 years, I leave whatever gas is in the tank, turn off the gas , run till it quits. Top off the gas with fresh in the spring, and it fires on the first one or two pulls, and runs as good as the day it was bought. I do the same with all my small engines.
The way Honda builds the switch into the fuel valve one can not do that. I took my eu1000i apart and did that years ago. Sold that and have an eu2000i that I have not yet added an off/on switch separate from the fuel valve. Chris
Well, the gas shutoff valve is not the only solution on these Honda 2000's. There is a plug that you can unplug, apparently there is a gas shutoff valve. If you unplug the connection when you turn the generator to off it continues to run for about 3 minutes, and quits ,same as adding a shutoff valve. Drawback is if its unplugged you are either waiting three minutes to fill it with gas , or just use the plug to winterize , but you have to get inside to do that .
This guy on youtube went one step further he added a switch ,where I added my gas shutoff valve, but wired in the switch ,so he could switch to where the generator remained running until it ran out the gas in the carburetor , or where when he shut it off it quit to add gas. Switch or gas shutoff valve , take your pick.
For me if I would of known , I would of done neither. As often as I winterize mine, I would of taken that front cover off unplugged that connection , and let it run until the carburetor was empty ,and it stopped running .
